Is it normal for the sound to stutter when Maximizing and un-maximizing the skin?
What should my sound settings be?
iMac 3.06 24"
512 video card
DJIO
iMac 3.06 24"
512 video card
DJIO
geposted Fri 13 Jun 08 @ 9:05 pm
          Does not happen with my internal sound card set to auto.
    geposted Sat 14 Jun 08 @ 7:19 am
          Are you using the DJio 1.5 driver for mac?
Kind Regards
Simon Bangs
Numark Cue Product Specialist.
    Kind Regards
Simon Bangs
geposted Sat 14 Jun 08 @ 4:36 pm
          Yes I am.  And last night the mouse and waveform kept freezing and unfreezing every few seconds and stuttering when maximizing and unmaximizing. Although the sound never stopped, its a pain when trying to mix when the skin keeps freezing.  3/4 of the way thru the night, I switched to the internal soundcard and although it happened once or twice it was much much less.
    geposted Sun 15 Jun 08 @ 2:19 pm
          Go to config > performances and move the slider to fastest and set auto latency.
What is your mac specification?
Kind Regards
Simon Bangs
Kind Regards
Simon Bangs
geposted Sun 15 Jun 08 @ 4:25 pm
          Thanks, I will try that.
iMac 24" 3.06.
4 Gig Ram
512 MB nVidia 8800 GS Video card
Leopard
DJIO with latest driver
Realtek, Internal Soundcard
    iMac 24" 3.06.
4 Gig Ram
Leopard
geposted Sun 15 Jun 08 @ 7:15 pm
