Forum: Old versions
Topic: Using a Roland SP-303 Sampler with Virtual DJ
I am trying to add some more effects with the sampler. I can hear it, but cannot record it. Can anyone help me?!?
Thanks a bunch!
Scubaay
geposted Tue 04 Jan 05 @ 5:50 pm
What do you mean add more effects? you can do this thru midi
config=>remote>enable midi device and create shortcuts to trigger whatever you want from 0 to 127 is the parameter possibilities
If you want to rec simply use any line out and patch to your input on the sampler
Andre
DJ Andre Landry,
Here is where I'm coming from.
I hear what you are saying about using MIDI, but unfortunately I do not have any MIDI interfaces.
I am only using my computer with Soundblaster Live Value. The Roland SP 303 is going from RCA Line Outs to a single 1/4" to my line in on the soundlbaster sound card.
I can hear the effects (i.e. lasers, space ship, etc), but I cannot record what I hear.
Any suggestions?!?
Thx
Scubaay
You need to make sure in the soundblaster live config menu called audio hq that you have the line input active as the record device and that the level is up
I agree with sowndman....here is a suggestion for Roland:why is'nt Dr sample midi compatible...did i miss something or what!!!
Andre
