I'd like to modify this because at the moment the led is on when the beat is off and vice-versa.
Could anyone help me to do it in the .xml file??
Thanks
Thanks
geposted Sat 14 Jun 08 @ 6:39 am
I try to explain better how, currenlty, this feature works:
When the beat is off, the led is red whereas when the beat is at maximun, the led is off; between these worths, colour of the led changes in linear way proportionately at the value of beat
geposted Sat 14 Jun 08 @ 8:29 am
Can you tell me what skin it is?
Nobody can help you if you don't know what skin it is :-)
geposted Sat 14 Jun 08 @ 9:49 am
It's this skin
http://www.virtualdj.com/addons/skin.html?id=2755
I'm bringing about several improvements about my favourite skin
geposted Sat 14 Jun 08 @ 10:01 am
## LEDs no CrossFader
<visual chan="1" type="transparent" source="beat">
<size width="7" height="7"/>
<pos x="460" y="523"/>
<down x="+0" y="+1024"/>
</visual>
<visual chan="2" type="transparent" source="beat">
<pos x="563" y="523"/>
</visual>
line 881
</visual>
</visual>
line 881
geposted Sat 14 Jun 08 @ 10:10 pm
Thanks
I'd like to change this instruction to do what I wrote earlier.
I tried with
<visual chan="1" type="onoff" source="beat">
</visual>
but it doesn't work as I want.
I don't know if one can get an instruction to do the complementary of "onoff"
I mean with
"onoff"=Display the up graphic if source>=2048, or the down graphic if source<2048
I would want "Display the down graphic if source>=2048, or the up graphic if source<2048"
Is that possible??
I tried with
</visual>
I mean with
Is that possible??
geposted Sun 15 Jun 08 @ 3:53 am
