Hi guys,
I'm building a new desktop which will be used for a multitude of things, one of which is a bit of DJ'ing.
What soundcard would you suggest for a desktop? My limit's around $250 if that comes into play.
Thanks!
Thanks!
geposted Sat 14 Jun 08 @ 9:47 am
Can't say if it's the best or not, but I use the M Audio Delta 1010lt PCI on my desktop. It's an excellent card at only $200, latency is almost non existant and stability is super. PCI cards like the delta are much faster than either USB or Firewire. The only drawback with this card is that you have to change the asiomapchainin in the registry, but it's easy to do & I can forward you the instructions if needed;^]
geposted Sat 14 Jun 08 @ 2:33 pm
I don't mean to be horrible and burst a bubble here, but it would be highly recommended to have a dedicated PC for dj'ing. Certainly if you'll be using it commercially for gigs and stuff...although I suppose if it's just for home use then fair enough.
Just an observations...and like i say, sorry to be bubble bursting.
Good luck...(",)
P
geposted Sun 15 Jun 08 @ 6:04 pm
I have a Maya 44 Pci you can have for $75.
http://www.esi-audio.com/products/maya44/
Nearly new, in fact never used.
It was a back up installed on MB only.
I see you are in Ma, PM me if you are interested.
Should be next day UPS.
geposted Sun 15 Jun 08 @ 6:47 pm
I prefer the E-mu 1212m. I think that it is about 149.00
geposted Sun 15 Jun 08 @ 11:03 pm
