First: I tried to solve my problem in the German forum without a good reslut, so I will try it here.
When I'm playing music after some time (sporadically) I cant start the new song, so Im pushing the play button but the song isnt starting. If Im restarting VDJ ist fixed.
I've not opened any other programs, I got the newest SK-driver, my external HDD where the music is locatet is FAT32 formatted.
My hardware:
SK: M-Audio Connectiv
Controller: Vestax VCI-100
Computer: MacBook Pro
Version: 5.08
I hope you can help me.
Thanks for reading.
Leo
My hardware:
Version: 5.08
Thanks for reading.
Leo
geposted Sun 15 Jun 08 @ 11:25 am
I need help! http://www.youtube.com/watch?v=RzdpT3KlyUA
geposted Sun 15 Jun 08 @ 12:38 pm
Why don't you open a new topic? I guess that your Problem isn't really similar to mine.
In the German forum I heard that Mr. skyfxl can solve this problem maybe.
Greets
Leo
Greets
Leo
geposted Mon 16 Jun 08 @ 11:38 am
Hi Jampgade87,
What is ur setting in ur sound setting n performances setting?
Ur using leopard or tiger?
N remember to select the quicktime audio codec for ur mp3;)
geposted Tue 17 Jun 08 @ 3:20 am
Hi, here are my settings:
http://img247.imageshack.us/img247/4281/bild3zv4.png
http://img234.imageshack.us/img234/975/bild2va5.png
Im using Leopard, the Quictime audio codec is activated.
geposted Tue 17 Jun 08 @ 6:57 am
ok try these first, reset to factory setting in the info tab. Play with it VDJ to see if the same prob occurs.
If still this not werkin, go to delete ur preference file then run the program again.
its located here :
yourcomputer/users/youname/libary/preferences
its called com.atomixproductions.virtualdj.plist
Also make make sure u updated ur leopard.
anyway i supposed u did have already make ur soundcard as aggregate device?
its located here :
geposted Tue 17 Jun 08 @ 7:20 am
Hi,
what do you mean with "aggregate device"?
It's a little bit difficult to try if the problem occurs, because sometimes it takes 4 hours that the problem is occuring, so at the weekend I will try.
Thanks
leo
Thanks
leo
geposted Wed 18 Jun 08 @ 5:56 am
Hi Jam, take a look at this recent thread for info on aggregate devices.
Best do the testing at home n not on ur gigs.
All the best.
Regards;)
All the best.
Regards;)
geposted Wed 18 Jun 08 @ 6:58 am
i've had this same problem and so have others...it has something to do with the midi controllers. I use total control and every now and then it happens to me. just move the jog wheel a little and it will free up the song. I've also heard that it may have to do with the usb plug that is next to the power cord but i haven't noticed a difference. (this is on mbp). But next time it
occurs, try just spinning your jog wheel on your controller to see if it releases the song.
geposted Sun 22 Jun 08 @ 12:07 am
I deleted all my old settings and tried it "clean", but the same problem occurs.
Dj Wizard: Im using the Vestax VCI-100 and I also tried by turing the jog wheel, without effect... But Im happy to notice that Im not alone :-(
geposted Sun 22 Jun 08 @ 3:34 pm
Hi. I have the same problem. it happen to me on mac. I tried to use windows XP on my mac using boot camp. The same thing happen ed once again. It starts pretty good, but after couple of mns, i just lose the control of the music while turntable send signal.
geposted Mon 23 Jun 08 @ 9:09 am
Just a quick thought but if you change your video files on options > codecs to quick time video decoder and audio to quick time decoder does this help?
Best Regards
Simon Bangs
Numark Computer DJ Product Specialist
Numark Alesis Europe Ltd
Best Regards
Simon Bangs
geposted Mon 23 Jun 08 @ 12:37 pm
The audio files are already running on the quick time decoder and I never use video files, do I still have to change the video files? Im not sure If that will help!?
geposted Sat 05 Jul 08 @ 10:30 am
