Hello there peopz',
I guess most of you don't know me on this forum as my last real activity here probably dates back to 2003/2004.
Back then I was still contributing to writing plug-ins for AtomixMP3.
Anyway as the timelords are a bit more "generous" towards me these days (traveling a lot internationally which means I usually have some time to kill in the airports or hotel rooms), there is a chance I might be able to contribute some again.
Guess all has been converted/ported since the early days.
However, if that is not the case just give a yell and I'll see what I can do.
Keep up the good mixing'.
DJ Corpse
DJ Corpse
geposted Thu 19 Jun 08 @ 3:35 pm
Hi,
Do you still have your source codes?
geposted Sat 21 Jun 08 @ 4:30 pm
Hi djcel,
No I don't. Had two harddisk failures since then, lost the source.
But I've made the effects before, so if anything needs to be recreated I guess I would figure it out.
Rgds,
DJ Corpse
Rgds,
DJ Corpse
geposted Mon 23 Jun 08 @ 3:41 pm
Maybe djcel required your source files to adapt your ones to newest versions of VDJ or also to improve those.
It's a shame you lost your sources because you made some great plugin for Atomix-mp3
geposted Tue 24 Jun 08 @ 7:55 am
