I downloaded the skin resizer and installed it... when I try to run it it tells me there is a new version available so I click and download the latest version and then when I try to open it it tells me the same thing and then closes. What do I need to do to get the program to work properly
Funkmasterfrank
Funkmasterfrank
geposted Fri 20 Jun 08 @ 5:27 pm
Hello, are you sure you are opening the version 1.0.8 when you downloaded that version, and not opening the previous version?
And is the date on you computer correctly set?
geposted Sat 21 Jun 08 @ 5:28 am
Same problem for me!!!!
previous version 1.07 is working!!!!
only 1.08 is giving that problem
Pc date is actual!!
Pc date is actual!!
geposted Sat 21 Jun 08 @ 9:53 am
I am trying it on a different computer and this time when I opened 1.0.6 and checked for updates it said there was an update so I clicked download but it doesn't go anywhere. Do you have the "rapidshare" download link or is it possible it has been removed from rapidshare?
Funkmasterfrank
Funkmasterfrank
geposted Sat 21 Jun 08 @ 10:34 am
i have a down loaded virtual dj pro how do i create a napster login
geposted Mon 23 Jun 08 @ 5:24 pm
@craig620
this is the wrong forum for this type of question. Please go to the general forum.
geposted Mon 23 Jun 08 @ 5:26 pm
