Forum: Old versions
Topic: loading mp3 to deck short cut
ok last question before i go vdj.. is it possible to have a shortcut key that allows me to load the highlighted mp3 to the decks.. i use keyboard shortcuts indtead of midi.
geposted Sun 22 Jun 08 @ 12:21 pm
Yes, you can map keyboard shortcuts to suit your tastes.....
ok so my friend has 5.1 what function is load deck labeled as, cause load file path is the closest i see but i give it a short cut of (L) but it does nothing.. but if i double click the mouse that works.. but i would rather hit L=load
Try hitting the space bar ;-)
thanks i feel like a dingbat been going crazy wit my home boy for 2 days trying to figure that...
