why Is that I can not save cue points, and cannot change the name tags and can not retain analized bmp settings on
certain mp3 tracks?
certain mp3 tracks?
geposted Thu 26 Jun 08 @ 2:08 am
Could you be a little more specific , perhaps an example of the track and its file name?
Kind Regards
Simon Bangs
Numark Computer DJ Product Specialist
Numark Alesis Europe Ltd
Kind Regards
Simon Bangs
geposted Thu 26 Jun 08 @ 12:49 pm
I'm not fully familiar with Cue/VDJ yet but you might want to check the ID3 tag version on the ones that you can't save to or work with.
It's very possible they use a very old or very new ID3 tag.
geposted Thu 26 Jun 08 @ 1:08 pm
DJEMF "'I' m not fully familiar with Cue/VDJ yet but you might want to check the ID3 tag version on the ones that you can't save to or work with.
It's very possible they use a very old or very new ID3 tag."
OK, when I get home I will check and try to change the ID3 tag version In Itune.
One more thing those songs were rip from a CD I bought last year.
skyfxl, do you want me to upload one of the tracks?
geposted Thu 26 Jun 08 @ 5:14 pm
OK, that worked. I convert those files with ID3 tag version V2.4 to V2.3 In Itune and inport them back In the playlist folder and they now work perfectly. I can save cue point and
BMPs. Thank you guys for the help.
geposted Thu 26 Jun 08 @ 11:50 pm
Please can you send a link to the file or the file to sbangs[at]numark[dot]com
Kind Regards
Simon Bangs
geposted Fri 27 Jun 08 @ 3:52 am
