This is posted on the web site
"You can still use your turntables to play real vinyls.
If you're using an ASIO soundcard, you just have to use the "bypass" mode (configure a keyboard shortcut for this action, or use a skin displaying a bypass button)."
I don't understand how to do shortcuts, can anybody help me in laymens terms?
geposted Fri 07 Jan 05 @ 7:27 am
Settings->keyboard shortcuts->Add..->Turntable->Timecode_bypass (+press a key in the keyboard and choose to wich deck) ->ok
I can't be more detailed, you have to spend some time in the keyboard shortcuts page
Its worth it, you can do miracles there.
geposted Fri 07 Jan 05 @ 7:45 am
Thanks apopsis. Do I do two different ones since I have two turntables?
geposted Fri 07 Jan 05 @ 7:50 am
As you wish !
geposted Fri 07 Jan 05 @ 9:02 am
