| Autor | - Topic: Vestax VCI-300 (Topic generale) - |
![]() ![]() http://ci.vestax.com/en/products/ Dati tecnici dichiarati dal sito ufficiale Vestax: # USB Port (Bus powered) # MIC INPUT x 1 # AUX INPUT:RCA x 2 # HEADPHONES OUT x 1 # MASTER OUT:PHONE x 2, RCA x 2 # INPUT FADER CURVE CONTROL x 1 # CROSS FADER CURVE CONTROL x 1 # DIMENTIONS : 410(W)x43(H)x275(D) (Excluding knob height) # WEIGHT : 3.2kg # ADAPTOR (OPTION) : DC-9V 500mA HIGH RESOLUTION CONTROL The VCI-300 can control more than 90 parameters and functions of the included Serato software with high resolution MIDI signals sent via USB. The pulse resolution of the JOG wheel and pitch control fader is 4 times higher than the VCI-100 and provides precise control of each function. The pitch control fader also shares the same high quality fader parts of the input fader for advanced operability. SUPERB AUDIO CHARACTERISTIC The built-in audio interface carries a Audio Codec IC with superb audio characteristic, generated by a delta-sigma modulation 24 bit stereo D/A-A/D converter. Audio connection includes 1 stereo input, 1 MIC input and 2 stereo output (Master L/R, Monitor L/R). LEVEL INDICATION A 12 level LED L/R indicator is set in the center of the top panel to monitor sound levels. FILE CONTROL Audio files in the software library can be easily selected and controlled with the CRATES / FILES / BROWSE key and the cursor switch inherited from the VCM-100. EMERGENCY THRU SWITCH The Emergency Thru Switch located on the rear panel is a countermeasure feature to avoid sound from stopping when the computer freezes. It instantly switches the output source from the computer to other audio players connected to the VCI-300. ADJUSTABLE JOG WHEEL TORQUE The torque of each JOG wheel can be adjusted to prevent them from moving from low frequency feedback and altering the pitch when using the VCI-300 in such places like clubs. FADER CURVE CONTROL The fader curve of each fader can be adjusted to the preferred characteristics for long mixes, scratching and any other style. |
Ciao Ragazzi,volevo in particolar modo rivolgermi ad Hackid che ha toccato con mano questo controller eccezionale!Volevo sapere come ti sei trovato con il pitch del Vci 300!Inoltre il cue è lo stesso dei cdj pioneer,oppure lavorerà come virtualdj?Le operazioni di messa in battuta sono semplici oppure le jog rispondono in maniera eccessiva ai comandi?Comunque sarebbe una stupenda notizia se questo controller con la prossima release sarebbe integrato nativamente!Un saluto a tutti e grazie! |
Grazie Cioce, la vostra discussione mi è stata molto di aiuto per risolvere alcuni dubbi!Ciao! |
... Secondo me, visto il prezzo, non ne vale la pena!... La RMX dovrebbe essere meglio; no? DJ ABARTH |
non proprio vai al link postato da Cioce e leggendo ti accorgerai che è superiore in molti punti la RMX è su un livello semi professionale questa è professionale |
... ok, ma ne vale la pena di spendere 350 euro in PIù per una Pro quando una semi pro costà così meno? Sicuramente .... DJ ABARTH |
..e non è supportata nativamente? questa nasce per ITCH !!!! |
Un ultima domanda su questo controller! Se non abilito il tasto scratch come funziona la jog weel? E' stato mappato anche in questo senso con virtualdj? Ciao!!! |
@ bioritmi Avrai penso notato che pochi italiani l'hanno provata con Virtual DJ. @ lory2001 Meglio usare il topic generale lory2001 wrote : Quisalve a tutti ce qualcuno che mi puo postare gentilmente qualche link di negozi che vendono questo controller grazie http://www.strumentimusicali.net/product_info.php/products_id/6981/risultati-ricerca/vestax-vci300-dj-midi-controller.html Ricordo a tutti che dalle FAQ http://it.virtualdj.com/forums/82749/Italian_Forum/F_A_Q___I_nuovi_utenti_sono_pregati_di_leggere_attentamente_qui_.html trovate i topic generali dell'hardware più diffuso ;) |
la ho comprata mercoledi mi arriva sicuramente non saro ingrado d'installarla spero che qualcuno di voi mi aiuti grazie |
lory2001 wrote : se dio vuole e arrivata ma come immaginavo non c capisco una mazza ho copiato la mappatura nella cartella di vdj apro il panello controller esterni ma non si vede la figura della vci300 e di conseguenza vdj non la vede cosa devo fare aiuto ho provato ad usare serato ma peggio che andar di notte chi mi aiuta a configurarla con vdj x favore aiuto La VCI-300 ovviamente non la vedi perchè non è ancora nativa, debi abilitare il MIDI e caricare il file XML che hai scaricato dal sito. Se continua ad avere dubbi -> http://it.virtualdj.com/contact/index.html e magari leggiti il manuale dove è tutto spiegato. |
non potresti x favore spiegarmi come faccio ad abilitare i midi t scoccia aiutarmi ad farla andare x favore |
Setup - controller esterni - tasto destro su general midi - impostazioni - carica così carichi il file xml che hai scaricato dal sito :) poi devi smanettare per cambiare i comandi a tuo piacimento! per il resto di ha consigliato bene Cioce. L'assistenza è il "luogo"migliore per essere seguiti alla risoluzione dei problemi! |
un ultima cosa x favore nel seup configurazione come devo mettere ? x poi riuscire a fare il preascolt grazie |
Ingressi timecode : nessuno output : cuffie+Casse driver : asio scusa se sono un pò rozzo ma vado a memoria perché non ho vdj qui per controllare :) |
scusami tu che non so scrivere ripeto meglio spero configurazione audio : ingressi uscite scheda/e scheda audio canali uscita come devo metterci ? scusami vrramente se t stresso ma ho una voglia di smanettare con questo bel ageggio che non t dico |
Lory leggendo in rete pare non ci siano driver ASIO nativi e serva installare gli ASIO4ALL ma a giuducare dalle banali domande che fai di Virtual DJ ci hai capito davvero poco (leggere il manuale è non è reato). Senza driver ASIO nativi dubito si possa arrivare ad avere una latenza decentemente bassa ma penso sia tutto voluto dalla Vestax cosi la gente lo usa con il suo software proprietario. Solo Moramax in assistenza può remotare il tuo PC e capire come settare il tutto, per l'ultima volta ti chiedo cortesemente di contattare l'assistenza http://it.virtualdj.com/contact/index.html |
http://it.virtualdj.com/forums/109662/Hardware_Technical_Support/VDJ6_and_Vestax_VCI-300_support.html Grazie all'utente jakovski un mapper quasi completo sta per essere ultimato, ovviamente ci sono delle limitazioni dovute a VDJ ma speriamo sempre che il grande capo torni dalla ferie! |
Immaginando di fare cosa utile mi sono fatto passare da un moderatore americano il setup audio, ovviamente vi servono gli Asio4All http://www.asio4all.com/ Su Virtual DJ 6.0.2 il mapper MIDI è nativo ;) http://it.virtualdj.com/homepage/cioce/blogs/3832/_ENG__Vestax_VCI-300_audio_setup_on_Virtual_DJ_6_0_2.html |
