Hi folks,
i wonder if it is possible to adjust the wave colors in a skin. It would be handy cause i am having some trouble with those colors ->partially colorblind. It would help me a lot.
Thx
Thx
geposted Fri 07 Jan 05 @ 9:13 am
It's no problem: Open the *.bmp (image) file from the skin's .zip, and edit the colors in any image editor such as Photoshop or even the Windows' MS Paint. You'll probably recognize which "object" represents the visual waveform.
geposted Fri 07 Jan 05 @ 11:07 am
thx for the help
geposted Fri 07 Jan 05 @ 7:03 pm
