Forum: Old versions
Topic: Sample save/load error
I downloaded V2.05
- I make loops in the sampler
- The work fine, i can play around with them
- I save it as eg. loop1.vdj
- the file is created but i cannot load it again
I tried this with and without the mp3 saving format
tough I can load existing loops, no probs here
I have ableton installed, maybe something to do with sampling memory
or is it a bug? THNX
great software!!, better then the combination traktor & ableton i used to work with
though i do not managed to beatlock my ableton samples yet..
geposted Fri 07 Jan 05 @ 3:51 pm
well, the version you are using is 2.01, and the problems you describe indicate that it's poorly cracked.
Either use the actual demo, or buy the full version.
that would be great, and if i can, i will,
thnx
