OK here is what I would like to do.. someone please tell me if it is possible or not cuz I can't seem to find a way to do it:
Player A has a song playing at 115bpm
Player B gets loaded up with a song that is 107bpm
I sync player B to 115bpm to match player A and set player B in a 4beat loop and match the beats manually
At some point while the song in player A is playing I start to blend in the song playing in player B
Now.. IS THERE A WAY for me to slow down the bpm of both songs "simultaneously" so that they stay beatmatched as they come down to the normal speed of the song playing in player B (107bpm)
(fyi I tried the beatlock feature but once I turn it on.. it seems I am unable to change the tempo anymore until I disengage beatlock. maybe I am just doing something wrong?)
geposted Mon 30 Jun 08 @ 3:10 pm
Hi,
ok so deck a is 115 n deck b is 107
U want to bring deck a to 107 rite, u need to press b (beatlock) at the deck b n then go to deck a and move the pitch slider to the desired pitch.
Or u could press b at deck a n just reset the pitch at deck b. It will werk vice versa.
Regards.
Regards.
geposted Mon 30 Jun 08 @ 3:27 pm
Ahhh ok got it!! I was trying to beatlock the WRONG player...
Just tried it and it worked AWESOME thanks!!!
geposted Wed 02 Jul 08 @ 12:27 pm
No problem. Njoy;)
geposted Wed 02 Jul 08 @ 12:46 pm
