Forum: Virtual DJ Plugins - Topic: Hecules RMX Mapper
Post here comments on the Virtual DJ Plugins (Audio effects, Video effects, Video transitions, Devices mapper, Tools, ...).
We remind that plugins are downloadable by registered PRO users only.
VirtualDJ Forum
Virtual DJ Plugins
Hecules RMX Mapper
Autor - Topic: Hecules RMX Mapper -
looshus
Limited edition user
Posted Fri 04 Jul 08 @ 4:57 am
Hi all, I've started writing my first plugin, to customise some buttons on the RMX. What I want to do is make the effect buttons have 'momentary' behaviour, and make the track search buttons skip 32 beats instead of 16. I've made a start but need some feedback off someone to check I'm going in the right direction.
Quote :
#define WIN32_LEAN_AND_MEAN
#define _CRT_SECURE_NO_DEPRECATE
#include <windows.h>
#include "vdjPlugin.h"
#include "vdjDevice.h"
#include "DJCMapper.h"
// Class definition
class LOOSHYBRO : public IVdjPluginDevice
public:
HRESULT __stdcall OnLoad();
HRESULT __stdcall OnGetPluginInfo(TVdjPluginInfo *infos) ;
HRESULT __stdcall OnButton(int chan,int button,int down);
HRESULT __stdcall OnSlider(int chan,int slider,int absvalue,int relvalue);
HRESULT __stdcall OnTimer();
HRESULT __stdcall GetDeviceType(int *type);
int skip_32;
//int effect_mom;
private:
// Initialisation
HRESULT __stdcall DllGetClassObject(const GUID &rclsid,const GUID &riid,void** ppObject)
// You don't need to change anything here
// Just leave it like that
if(memcmp(&rclsid,&CLSID_VdjPlugin,sizeof(GUID)) != 0) return CLASS_E_CLASSNOTAVAILABLE;
if(memcmp(&riid,&IID_IVdjPluginDevice,sizeof(GUID))!=0) return CLASS_E_CLASSNOTAVAILABLE;
*ppObject=new LOOSHYBRO();
return NO_ERROR;
char _strparam[128];
inline char *strparam(char* s, int v) {wsprintf(_strparam,s,v);return _strparam;};
HRESULT __stdcall LOOSHYBRO::OnLoad()
DeclareParameter(&skip_32,VDJPARAM_SWITCH,1,"Skip 32 beats with track search buttons",1);
//DeclareParameter(&effect_mom,VDJPARAM_SWITCH,2,"Make effect buttons momentarily active",1);
return S_OK;
HRESULT __stdcall LOOSHYBRO::OnGetPluginInfo(TVdjPluginInfo *infos)
infos->PluginName="RMX Looshus Skip 32";
infos->Author="Luke Davies";
infos->Description="Looshus RMX extentions";
// Replace the files "BITMAP.BMP" and "SELECTED.BMP" in your directory with your own.
infos->Bitmap=LoadBitmap(hInstance,MAKEINTRESOURCE(100));
infos->Flag=0;
return S_OK;
HRESULT __stdcall LOOSHYBRO::OnButton(int chan,int button,int down)
if (button=DJC_PREV_TRACK_A)
SendCommand(strparam("skip_beat",-32),0);
return S_OK;
return E_NOTIMPL;
HRESULT __stdcall LOOSHYBRO::OnSlider(int chan,int slider,int absvalue,int relvalue)
return E_NOTIMPL;
HRESULT __stdcall LOOSHYBRO::OnTimer()
return E_NOTIMPL;
HRESULT __stdcall LOOSHYBRO::GetDeviceType(int *type)
* type=PLUGINDEVICE_DJCONSOLE;
return S_OK;
I've only tried the one button so far, is my
Quote :
return S_OK;
bit OK?
Where do I go from here? do I need to compile the dll, call it DJC.dll and put it in the control device folder?
Any help greatly appreciated, Loosh.
djcel
Senior Team
Posted Sat 05 Jul 08 @ 6:54 am
You need the new "DJCMapper.h" file in order to write a mapper for the RMX
The dll has to be named : rmx.dll
looshus
Posted Sun 06 Jul 08 @ 6:51 am
Thanks for getting back to me, where can I find the new DJCMapper header file? The one available on the developer page seems to be for the mk I and II controllers and not for the RMX.
djcel
Senior Team
Posted Sun 06 Jul 08 @ 5:07 pm
Currently, I'm the only one to have it and it's not yet online.
looshus
Posted Sun 06 Jul 08 @ 5:36 pm
No chance I could get a sneak preview? ;->
What sorta timescale we lookin on????
Moramax must have it aswell?
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
