Need help setting up the network settings so that two laptops can be linked together, using a crossover ethernet cable between the two laptops.
What do we need to do to enable synchronisation?
geposted Sat 05 Jul 08 @ 10:04 am
Select "Network synchronysation"
It works like a server-host
=> The host needs to know the IP of the server
(verify that the port is not locked by the firewall)
Then use the beatlock to synchronyse
geposted Sat 05 Jul 08 @ 10:33 am
How do i find the IP address and port number?
geposted Sun 06 Jul 08 @ 8:11 am
start -> run -> cmd -> ipconfig
will show your ip. Might want to consider changing your IP to something static in tcp/ip config to make life easier.
turn off your firewall (software) so the port doesnt get blocked
start -> run -> services.msc
look for things like Windows Firewall, Windows Defender, Zone Alarm, or whatever you may have installed.
personally, Ive never tried this feature. I think i might though....
geposted Sun 06 Jul 08 @ 8:50 am
