Forum: Music discussion
Topic: help with vj online radio
hello
my problem is this
i make an online radio with virtual dj and i can listen it in my pc but when i give the link to other people, they cant play it, an error appears, i want to know what ia have to do, i configure evertyhing right, i think, so i dont find the problem
please help :(
geposted Sun 06 Jul 08 @ 12:33 am
thank you so much
it works now =)
but i have another doubt
sorry jaja
i want to know if i can talk through the mic just like a real radio, and what and how i have to do to talk in the radio.
that's all
thank you very much =)
Choose broadcast from MASTER + MIC in the broadcast setting.
And enable MIC as input in windows soundcard settings
And if you like the software, hope to see you as a full member one day...
https://virtualdj.com/buy/
yes, as soon as i can
hey i found another problem XD im full of problems please help
each time that i broadcast my radio, the ip is different, cant i have always the same ip? so i can give the link to my friends and thay can listen, and they can save that link
please help
@faku10: i hope that you don't use a crack's version of VDJ!!
if you don't want any problems, if you want to have a perfect software, go here:
bye
please help
that depends on your Internet provider. If you have a dial-up connection, you will get a new IP each time you connect.
If you have broadband, your IP should stay the same for as long as you are online.
You can call your internet provider, asking them to have same IP, but it usually cost a bit.
There are online radio stations you can broadcast to though, that will give your friends the same adress to connect to you each time.
Here is one : http://www.listen2myradio.com/ (free)
Hope that helps.. :)
Guys i am new to vritual dj and i have a web radio like the other man i know to talk you need to go to broadcast config and then choose master+mic but with that way the mic is always on and everyone can hear you anytime. Is there a way to open and close the mic only whenever you want to talk?
