Forum: Old versions
Topic: VDJ software won't close!!!
Everytime I try to close the software, it doesn't respond. Any changes I made during that session don't save. Is anyone else having this problem? At first I thought it was my ultra-latency option because after unticking that box in sound settings, the program would close normally. But now I'm using a different interface and leaving the ultra-latency option un-ticked and VDJ is doing it again. I can only assume that it is some setting in my computer, because support said I was the first one that reported this issue. Already tried re-installing.
geposted Fri 11 Jul 08 @ 5:57 pm
Go in the config and disable the options "Charts"
Which sound card are you using?
RME Multiface 2... but I've narrowed it down to the General Midi option in remote control settings. I can activate it fine, but when I try to deactivate it or just close the program when it's active, that's when I have the problem. I've submitted a ticket but if you have any other suggestions, I'm all ears.
So which MIDI controller are you using?
