Forum: Old versions
Topic: Monitoring Samples with the M-Audio Firewire 410
Does anyone know if you can configure the 410 so that you can hear the samples being used in the house mix on the montior mix too? The advanced config options mean that you can only send it to one or the other...
geposted Mon 10 Jan 05 @ 10:33 am
just use the advanced config in the sound setup section and config the samples to a 3rd output and input it into your mixer. or if you want to sub mix each sample into a different channel you can also do it, have a look and you'll figure it out pretty easily
