I've got a white Macbook, NUMARK AXIS 9 cd players and Rane SL1 (SERATO) box. I've attempted to use my VDJ time code CDs with the SL1 but each time I try to configure my set up, VDJ quit unexpectedly! What the %^# !!!! I need some advice. When I started up SERATO it seemed fine, BUT I DON'T WANT TO RUN SERATO. HELP!
geposted Tue 15 Jul 08 @ 8:39 pm
djtonyidol, from what i remembered reading; i believe that the Serato is purposely block their Serato box to exclusively be used with the Mac version Serato software.
You may need to use another soundcard like VV numark
geposted Tue 15 Jul 08 @ 9:53 pm
where can you get the Virtual Vinyl soundcard without buying the program all over again. I thought I was told on one these forums that the SL1 would work with VDJ?!
geposted Tue 15 Jul 08 @ 10:06 pm
Direct quote from HiTower" a lot of users have the Audiotrak Maya 44 ($100). I've had success with the M-Audio Fast Track Pro ($200)."
geposted Tue 15 Jul 08 @ 10:11 pm
Yes exactly
geposted Wed 16 Jul 08 @ 7:15 am
We've got VDJ users on the PC threads that say they use SL1 no problem. is this a Mac issue and do you recommend maya44 as an alternative?
geposted Wed 16 Jul 08 @ 11:05 am
You can use SL1 on Windows but not on MAC OS with VirtualDJ
geposted Wed 16 Jul 08 @ 11:27 am
To use time code, you'll need the Virtual Vinyl interface, or the Hercules MK2 controller. You have to buy the Virtual Vinyl package to get the interface. I've tried eBay, but I haven't found anyone just selling the interface yet. Version 5.1 is supposed to fix the time code issues. From what I understand, it's in beta testing now. As for the Maya 44, I don't use it but it seems to be pretty popular.
geposted Wed 16 Jul 08 @ 1:00 pm
Does maya work with timecodes?
geposted Sat 19 Jul 08 @ 3:38 am
To my knowledge, it doesn't support timecode on a Mac.
geposted Sun 20 Jul 08 @ 12:40 am
