Posted this in the General Discussion forum since I thought it was checked more frequently but so far 15 reads and no reply ... I should have probably posted this here since this is the correct forum..
Would appreciate the help.
My VCI-100 finally arrived today thanks to Guitar Center sending my order out on Monday instead of Friday!!!
Questions:
1) I'm not a vinyl mode user - is there anyway to set the main platters to pitch bend instead of being forced to use the outside? I don't like the vinyl mode because if I brush my hand on top of the platter it stops. With it out of vinyl mode it "searches" through the track.
2) How can I create pitch bend +/- buttons? That is what I am used to on cd dual decks and the Numark DMC-2
3) In regards to loops and the controller...how do I toggle back and forth between Deck 1 and Deck 2? The only way I figured out doesn't make any sense and that is when you use the controller to load a song on Deck 1 while Deck 2 is playing then the Loop buttons work for Deck 1 but not Deck 2 and vice versa.
I'm "mapper stupid" so keep that in mind when replying. :)
Thanks!!
Jay
Questions:
Thanks!!
Jay
geposted Thu 17 Jul 08 @ 7:04 am
ignore the above, wait...that's already been done - I figured it out already.
Thanks for the help (sarcasm).
geposted Fri 18 Jul 08 @ 3:12 pm
Jay, please do not double post. You should look for your answers in the thread from the General Forum..Thanks
geposted Fri 18 Jul 08 @ 3:19 pm
