Hey,
I just installed Virtual DJ 5.0 on my MacBook Pro and was wondering how do I activate the Jog Wheel mode. I want to basically pitch bend the music from the turntable. I see the shortcuts but am not sure which one to set and what value to set it too. Thanks
geposted Thu 17 Jul 08 @ 5:15 pm
Question number why are you using 5.0, the latest demo I belive is 5.07, download that. If you are using a turntable you must use VDJ wax, with version 5.0, then choose absolute mode, and you can pitch bend all day long. I would strongly encourage you to buy the program, the latest version 5.1 is the sh*T, you will not be dissappointed. I'll be checking back to see if you become a registered users.
take care
take care
geposted Thu 17 Jul 08 @ 6:46 pm
