ok...i'm having trouble with the video and audio since i have started isung the video recording on vdj app
even now if i'm not recording the video play it does not sync with it's own audio
i can see the video perfectly and hear the audio is perfectly clear but they don't sync together
this happen if i need to slow or speed up using pich
also looping before mixing ....
it does this more on the track # 2..
i have check everything.......is not my pc is not the codecs is not the setting i have ckecked all.....
my pc is running perfectlu...even i have re-installed all AGAIN...!
P.S.:
It will be great if we can get to record on mp4 directly or mpeg
also it needs to give us the option to keep the eq.set to remember their position at statrup..
i have disable hardware acceleratin and it runs equal video and audio
But can't use effects, transiton ,can't scratch ...
...anyone knows the better setting for video recording w/vdj?????
P.S.:
geposted Fri 18 Jul 08 @ 9:59 pm
