Hello,
VDJ 5.1 works really great.
But there is one thing that sometimes happens.
Also yesterday, when I did my gig.
I wanted to search for a song but I couldn't typ something in the search bar.
Strange is that my virtualdj screen was maximized and when I made the screen smaller I could typ again.
It happens only after a while when I'm doing my gig for a couple of hours.
Does anybody knows this problem and can tell me how to solve this in the future by letting my virtualdj screen maximized?
Thanks
Thanks
geposted Sun 20 Jul 08 @ 5:11 am
Just minimize vdj, click anywhere in the desktop, then maximize again and all will be well. I too have noticed this and it is usually only after an effect is closed (in my case).
geposted Sun 20 Jul 08 @ 5:29 am
discobrian24,
Thanks for the very, very, very quick reply.
Yes, you're right. It happened also after closing an effect.
But I didn't dare to maximize the screen again after I minimized it and noticed that I could type again.
Ok, just have to keep this in mind when it happens that I can solve it this way.
Thanks buddy.
Thanks buddy.
geposted Sun 20 Jul 08 @ 5:36 am
yes right and if this happens while doing radio you loose connection!!!!!not so good:-(
geposted Sun 20 Jul 08 @ 7:17 am
I noticed this as well. Don't double click or you might crash it. I click on a music folder then go back in the search field again and it seems to work again.
geposted Sun 20 Jul 08 @ 3:17 pm
fatkatzdj,
That's better then minimize.
Gonna try it next time when it happens.
Thanks
Thanks
geposted Sun 20 Jul 08 @ 3:20 pm
