Hello there...I have vdj pro..and every time i record an mp3 set..somewhere along the lines of the mix..theres a skip, now this can happen from once to every now and then in the mix..i can't hear it when Im mixing but when I do a play back I hear it...now this is weird for me...I thought it mite be an installation problem so I installed it again and I still get the same error. Can anyone give me some help on this or am I a First?
Thanks
Sia
Thanks
Sia
geposted Sun 20 Jul 08 @ 10:13 am
are u using the lame codec from vdj...?
try using other lame codec from google search ....
also check if there any other applicationrunning in the backgroung...if in on Windows Vista it can be happen a lot.. stop application from running..
geposted Sun 20 Jul 08 @ 7:30 pm
Yes mate I am using Lame ..and usually I have nothing running in the background but still I get the odd skips any other ideas?? cause I am really bummed!
geposted Mon 21 Jul 08 @ 4:38 pm
ok..try this...use the default settings on your sound card device.... and go to vdj performance and set auto,uncheck save mode ,scratch set latency simple,and the temo set fast,and 44-48 simple,oh use preset all to the left try that..
geposted Wed 30 Jul 08 @ 10:48 pm
