Forum: Old versions
Topic: External Mix Board
Is it possible to use a external mix board with virtualdj 2. And if it is, How do i go about?
geposted Tue 11 Jan 05 @ 7:41 am
1st. you need a full version of the software
2nd. it's good to have 2 stereo outputs from your computer (2 soundcards / 1 soundcard with 2 or more stereo outputs)
3rd. just connect outputs from your soundcard to each channel of your external mixer.
You can also get a stereo-splitter to use two mono inputst for mixtable. All these options are avalible in the configuration menu.
