Hi, I've been a bit stupid and I have activated a skin which is too large for my screen. This would be fine if the config button on the skin was up top, but this skin has the config button at the bottom, and I cannot manoeuver the VDJ window to bring the bottom of the window into view, and so cannot get to the config button to open the settings and get back to the skns options.
is there a keyboard shortcut to the config options?? if not what can i do?
cheers - john
cheers - john
geposted Mon 21 Jul 08 @ 3:30 pm
You can delete the Skin from your Documents/Virtual DJ/Skins folder. When you open Virtual DJ it will then revert to the default skin.
geposted Mon 21 Jul 08 @ 3:39 pm
genius!! Thanks matey!!! john xx
geposted Mon 21 Jul 08 @ 3:54 pm
