Forum: Old versions
Topic: DJ Console MK2 connection problems
Problem........
I have the DJ Console MK2 running Windows XP.....Computer will not install Drivers to operate DJ Console...It keeps telling me the Console is disconeccted.....I have downloaded the update drivers and it still does not work, when it tells me the computer is installing the drivers, I get about four green installation bars and it just stays there and doesn\'t install the drivers. I have noticed a yellow ( ? ) in the hardware device manager section meaning there is a conflict with the hardware, but I can\'t find the device it conflicks with....Need help ASAP....
geposted Tue 22 Jul 08 @ 2:37 pm
First of all try a different USB port to install. If it does install always use that port.
If you are having driver installation problems, you will most likely get better - direct - support from Hercules.com
http://ts.hercules.com
