Ok.
so I have downloaded the fader start plug in and set it in the effects boxes of each virtual DJ deck. I then programmed the djm-800 to start each deck when crossfading.
For those that are still wondering, yes it works by programming the DJM-800 crossfade as this particular effect
Here is the new problem.
When the crossfader slides all the way to the left, Deck two will stop playing and reset to the beginning to the song, which is what I want it to do.
However.....
When the crossfader slides all the way to the right, Deck One will stop playing but will just pause where the song is at and not cue back to the beginning.
How do I get deck one to mirror deck two???
However.....
geposted Wed 23 Jul 08 @ 6:09 am
You have to select the mode "Stop" instead of "Pause" in the plugin
geposted Wed 23 Jul 08 @ 1:30 pm
Where is this Fader start plugin, I can't find it.
geposted Wed 23 Jul 08 @ 1:35 pm
Found it
geposted Wed 23 Jul 08 @ 5:55 pm
