Hey
heres my situation. i have a gig @ CiRCA Toronto comming up soon and the other dj im dj'n with uses serato :0
is there a way to split the output from the pioneer cdjs to go through both soundcards without effecting the timecode quality?
geposted Mon 28 Jul 08 @ 1:58 am
why use 2 programs? if your using TIMECODES i would think that 1 of you or both can beatmatch by ear, after all you are a DJ?
anyways you could use the SERATO BOX with NVV. you would have to just unplug the USB from one laptop to another. i dont know how you are with time, but if you do this MAKE SURE TO SHUT THE PROGRAM DOWN BEFORE YOU PLUG THE SERATO BOX IN. not sure why but when i tried to change things up with the program running it would not recognize the SERATO BOX. i had to do this about a month ago. anyways i would say as long as you both are not running at the same time it shouldnt effect the quality. thats just me, but hey some one here will be able to help u. later and happy spinnin!!!!
geposted Mon 28 Jul 08 @ 11:43 pm
