Just downloaded the new version http://www.virtualdj.com/update.html
but i havent figure out whats new.
geposted Mon 28 Jul 08 @ 5:06 am
An official 5.2 topic will come from team, please have patience ;)
geposted Mon 28 Jul 08 @ 5:33 am
I haven't seen an official "history" release on 5.2 yet.
If you look at your remote control tab in config, you will see some changes.
Might see a couple of other things fixed, but not sure without the official report.
geposted Mon 28 Jul 08 @ 5:58 am
Here is the official changelog
geposted Mon 28 Jul 08 @ 7:45 am
"Vista UAC crash (PC)"
Which crash was this?
geposted Mon 28 Jul 08 @ 10:20 am
There's been a few crash where Vista's UAC crap was involved, I can remember reading about them in DJ cel's crash explanations.
geposted Mon 28 Jul 08 @ 10:41 am
first thing to do if you´re running vista,and are an experienced user is to turn of UAC. causes lots of issues,not only in VDJ,but also when running install of other software/hardware. SP1 solved some of those issues,but there´s still lots to fix. I think that vista has great potential, but there are some small details to take care of.
geposted Mon 28 Jul 08 @ 10:46 am
Is there a problem with the Download Center?
I insert my License Code and it does not show any updates or anything?
Never had this problem in the past so just checking, etc...
Thanks,
DJ TAO :)
Thanks,
DJ TAO :)
geposted Mon 28 Jul 08 @ 1:30 pm
Thanks,
DJ TAO :)
Thanks,
DJ TAO :)
it's not the License Code but the forum password ;-)
geposted Mon 28 Jul 08 @ 1:37 pm
How do you turn off user account control?
geposted Mon 28 Jul 08 @ 2:07 pm
Method #1 - Using MSCONFIG
Launch MSCONFIG by from the Run menu.
Click on the Tools tab. Scroll down till you find "Disable UAC" . Click on that line.
Press the Launch button.
A CMD window will open. When the command is done, you can close the window.
Close MSCONFIG. You need to reboot the computer for changes to apply.
Note that you can re-enable UAC by selecting the "Enable UAC" line and then clicking on the Launch button.
Method #2 - Using Regedit
Open Registry Editor.
In Registry Editor, navigate to the following registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System
Locate the following value (DWORD):
Enable LUA and give it a value of 0.
Note: As always, before making changes to your registry you should always make sure you have a valid backup. In cases where you're supposed to delete or modify keys or values from the registry it is possible to first export that key or value(s) to a .REG file before performing the changes.
Close Registry Editor. You need to reboot the computer for changes to apply.
In order to re-enable UAC just change the above value to 1.
Method #3 - Using Group Policy
This can be done via Local Group Policy or via Active Directory-based GPO, which is much more suited for large networks where one would like to disable UAC for many computers at once.
If using Local Group Policy you'll need to open the Group Policy Editor (Start > Run > gpedit.msc) from your Vista computer.
If using in AD-based GPO, open Group Policy Management Console (Start > Run > gpmc.msc) from a Vista computer that is a member of the domain. In the GPMC window, browse to the required GPO that is linked to the OU or domain where the Vista computers are located, then edit it.
In the Group Policy Editor window, browse to Computer Configuration > Windows Settings > Security Settings > Local Policies > Security Options.
In the right pane scroll to find the User Access Control policies (they're down at the bottom of the window). You need to configure the following policies:
You'll need to reboot your computers.
Method #4 - Using Control Panel
Open Control Panel.
Under User Account and Family settings click on the "Add or remove user account".
Click on one of the user accounts, for example you can use the Guest account.
Under the user account click on the "Go to the main User Account page" link.
Under "Make changes to your user account" click on the "Change security settings" link.
n the "Turn on User Account Control (UAC) to make your computer more secure" click to unselect the "Use User Account Control (UAC) to help protect your computer". Click on the Ok button.
You will be prompted to reboot your computer. Do so when ready.
In order to re-enable UAC just select the above checkbox and reboot.
Choices enough
Greetings,
DjAnthony
Open Control Panel.
Choices enough
Greetings,
DjAnthony
geposted Mon 28 Jul 08 @ 2:29 pm
Thanks for that! I'll take a look.
geposted Mon 28 Jul 08 @ 2:34 pm
Your welcome.
If you decide to disable any one of Windows Vista Security Center features your bound to get annoyed by the little pop up balloon when ever you log on. Here's how you can disable that warning!
Step1 Right click on the little red shield on the lower-right bottom corner of the screen.
Step2 Highlight "Open Security Center" and click on it.
Step3 Click the link for "Change the way Security Center alerts me"
Step4 Click "Don't notify me and don't display the icon" and you're done!
geposted Mon 28 Jul 08 @ 2:40 pm
Thanks,
DJ TAO :)
Thanks,
DJ TAO :)
Thanks!!!
My bad reading (LOL)
Thanks again,
DJ TAO :P
geposted Mon 28 Jul 08 @ 5:44 pm
i dont even have version 5.1 :(
geposted Mon 28 Jul 08 @ 7:37 pm
I feel ur pain
geposted Mon 28 Jul 08 @ 7:50 pm
Is it the Virtual DJ work with windows vista?
geposted Fri 01 Aug 08 @ 9:24 pm
Yes it does.
geposted Sat 02 Aug 08 @ 6:48 am
Hey Numark Team. Any idea on the 5.2 release for MAC or when Numark will get the updates? ... or are you waiting untill Atlantic City
geposted Mon 04 Aug 08 @ 12:24 am
