Forum: Old versions
Topic: Clock display on VDJ5 Hard to read!?
Hi Guys,
I'm hoping this will be a simple font issue, not sure?
I've installed the latest version of Cue 5/VDJ5 on a clean XP install and I've notice no matter what skin I choose the clock display is really hard to read, it's like VDJ is choosing the wrong font or something, or the font it wants to use is unavailable?
Here's a screenshot;
http://capitalnightlife.com.au/blurryclock.jpg
It doesn't matter what skin I choose, or at what resolution my display is set at (currently 1280x1024 on a 4:3 monitor), the clock always looks the same.
Any help would be much ablidged.
Regards,
Graeme Lucas @ capitalnightlife.com.au
geposted Mon 28 Jul 08 @ 7:46 am
It's because most of the skin designers are using a L.E.D. font and it seems that it's not rendering right on your system.
If you have a particular skin you like you can easily modify the XML to use a font that works for you. Please see the skins forum for how easy the change can be. https://virtualdj.com/forums/13/Skins.html
Try reinstalling the LED fonts first, it might be the solution.
Where is the LED font?
Thanks for the information guys, really appreciated, I'll give this a go tonight when I'm home and let you know the outcome.
Thanks again!
Hello again, I've been out gigging all weekend so haven't had 5 minutes to go on the computer!
Well the LCD font didn't resolve the issue, in fact I already had that font installed!
I fixed the problem by actually deleting the LCD (TT) font from my system, not sure if this will have any adverse effects on the computer, but immediately the clock changed to a more sensible font that I can actually read!
If anyone has a better solution please let me know but for now I'm happy!
Regards,
Graeme Lucas
Well I did say try Re-installing them, as it was probable you already had them
on your system.
Now when VDj does not find the correct font it uses the default ones that are
available on your system. Removing a font cannot have any affect on your computer
except you won't be able to display that type of fonts, or software (if smart enough)
will display them as default type.
You can manually change the font in skin's .xml file by opening the file in text editor
and replacing this parameter of "fullhour" text object:
<text font="LCD" size="13" color="#FFFFFF" align="left" weight="bold" format="%fullhour"/>
with any other font="" you want, which Cstoll already mentioned...
One more solution might be to instead of changing the font type, try increasing
the size of LCD font, so they would be displayed more clearly on your resolution
(same way as above).
Ahh I'll definately give the xml thing a go, I'm fairly confident in what I'm doing anyway!
I did try reinstalling the font, sorry should have mentioned that! But it didn't fix it.
I'll give the xml tweak a shot..thanks!
Graeme @ capitalnightlife.com.au
