Finally i now have some time to rewrite my DAC2 and DMC1 mappers with the new SDK.
I see that an OnParameter function is added in the default source code, how can this be used in a device mapper ?
geposted Mon 28 Jul 08 @ 1:30 pm
When you define DeclareParameter() in the OnLoad function, you give an ID. Then this ID is sent to OnParameter when you use the Parameter defined
There is an example in the new plugins SDK Wizard
geposted Mon 28 Jul 08 @ 1:34 pm
I understand how it works, just thinking about what functionality to use it for.
geposted Mon 28 Jul 08 @ 1:35 pm
I use them in device mappers for things like having sliders for sensitivity for scratch, jog and bend. Other possibilities include switching between alternate mapping profiles, changing beat sensitivity for beat indicators and so forth...
Regards,
Scott
Regards,
Scott
geposted Mon 28 Jul 08 @ 4:10 pm
