I'm wondering if it's possible to update to version 5.2 and still have my current version operating? I've seen there are some issues with the upgrade and don't want to get rid of 5.07 until I'm sure 5.2 will work for me. Thanks for the help.
geposted Mon 28 Jul 08 @ 4:34 pm
Good question. I'd like to do the same.
geposted Mon 28 Jul 08 @ 10:21 pm
Yes of course you can have 2 .app files but you have to know that the database and the settings are common.
geposted Tue 29 Jul 08 @ 6:18 am
All you have to do is: Rename the program file "virtualdj" (virtualdj.app) to ex: "virtualdj_5.07" (virtualdj_5.07.app). Then you install the update!
Good luck!
Good luck!
geposted Tue 29 Jul 08 @ 9:58 am
Cool. Thanks for the help.
geposted Tue 29 Jul 08 @ 3:43 pm
