Forum: Old versions
Topic: Lights stay on
The lights on the console stopped working does anybody have a clue why?All controls work!
When i shut down with icon exit and reopen it works fine.
Thanks
Andre
geposted Wed 12 Jan 05 @ 10:30 pm
Happened again????hello help
Insufficient power available from your USB port *maybe* ? Some can supply more current than others.
Perhaps try running the DJC through a powered external hub and see if that fixes it.. or it could be a fault in the DJC.
Hercules is recommended to run on a powered hub.
I run mine without, directly connected to usb port at laptop. And it works fine. But power supply can be a problem.... some usb ports have bad power supply
