Need: Firewire live video feed from Sony 8mm digital camcorder into PCDJ VJ on Sony laptop to be displayed on projector screen.
Problem: Camera.dll plugin provided with PCDJ VJ has flickering white vertical lines over video signal apparently from firewire signal being too 'hot'.
Initial Solution: S-video camcorder directly into projector. Drawback: Limited to 4 or 5 digital effects on camcorder.
Second Solution: PeteLiveFeed.dll (www.petewarden.com) freeframe plugin provided crystal clear video signal. Drawback: PeteLiveFeed.dll reads VIDEOMEDIATYPE as RGB32 instead of YUY2 resulting in video signal being read bottom-up as oppesed to top-down causing the video signal to be inverted vertically and horizontally.
Final Solution: Using FFRend (ffrend.sourceforge.net) create a metaplugin with 3 of Pete's plugins:
PeteLiveFeed.dll provides live feed video signal.
PeteSlide.dll with settings tweaked to provide image correction.
PetePanSpinZoom.dll provides slight scale adjustment to hide sliding effect off screen.
PeteLiveFeedInvertFix.dll can be downloaded here:
http://pages.cthome.net/shawnmcd/pcdjvj/PeteLiveFeedInvertFix.zip
Sincerely,
Shawn McDonald
Sincerely,
Shawn McDonald
geposted Tue 29 Jul 08 @ 8:33 pm
