Are there any visualizations for Virtual DJ like the ones on Media player and Winamp, and if so where can I get them?
geposted Wed 30 Jul 08 @ 7:26 am
VirtualDJ is compatible with Sonique visualisations. Registered users can download a test pack of plugins from this site, otherwise google is your friend in finding various plugins. Beware some plugins are not compatible or are coded for a specific host application. Some will throw a fit if winamp is installed.
geposted Wed 30 Jul 08 @ 7:55 am
I have googeld it but have found nothing uselfull. I did however find Winamp wrapper for AtomixMP3 but dont have a clue how it works.
geposted Wed 30 Jul 08 @ 9:01 am
AtomixMP3 is not the same as VirtualDJ.
I did a quick google, came across a few links with various Sonique plugins. I do not know if they will work in VDJ or not, you will have to test them yourself. Here are a couple of examples:
http://support.xmplay.com/file.php?cat_id=6
http://www.sureloads.com/userfiles/7113/sonique-vis.zip
geposted Wed 30 Jul 08 @ 9:17 am
The visualizations from Boxee media center are the best, i wish there was a way to use them.
geposted Sun 13 Feb 11 @ 5:01 pm
Ooooold thread dude.
IIRC Boxee uses ProjectM which is a milkdrop compatible system and being OpenGL based would be an absolute pain for VDJ under Windows.
geposted Sun 13 Feb 11 @ 6:47 pm
Bumping this thread because it shows up in various Google searches.
So now that you know why, could someone please post a working link for a visualizations pack so that future Googlers don't have to do so much searching? I can't even find anything from searching these forums! Why is it so hard to find any?
EDIT: The section on the site to find them is poorly-worded. You can find them in the Video Effects portion of the Effects Plugins category. Here's a direct link to a decent pack that should cover most people's needs:
http://www.virtualdj.com/addons/4207/72_Sonique_Visual_plugins_certified.html
For those of you coming from Google, you'll have to register your controller/software on this site in order to download them.
geposted Tue 28 Jun 11 @ 7:25 pm
