Guys,
Has anyone noticed that when you try to dl this skin only one file comes through and it is not in a zip directory? Bad download maybe?
Killabee44
Killabee44
geposted Thu 13 Jan 05 @ 5:27 am
Hi,
Maybe it's your Internet navigator, do you use IE6 ?
If not, change the extension of the file for: .zip
Coyote
Coyote
geposted Thu 13 Jan 05 @ 6:24 am
Thanks Coyote... You were right. I just had to change the extension. Let me ask you a quick question while Im here...
I downloaded this skin and in the skins dl page fruit said:
"PANNELS! You'll find a "very crossfade" panne and a "Pros with mixer" one."
Now, where can I get the version without a crossfader? There was only one version in the .zip file. Thanks.
Killabee44
Killabee44
geposted Fri 14 Jan 05 @ 5:11 am
Load the normal skin and press the small "3" button above the word "mode" in the middle of the screen.. voila, crossfader gone..
geposted Fri 14 Jan 05 @ 9:08 am
Got it. Thanks.
geposted Sat 15 Jan 05 @ 10:22 am
