Forum: Old versions
Topic: HDJC 5 console mapper gone
Since I've upgraded to HDJC 5 package the console mapper is disappeared.
When you right click on the green alien in the task bar, the option simply doesn't show up.
Yesterday I re-installed HDJC4 package and there it was again.
I looked into the folders of Hercules\Audio... and found the DJMapper.exe
Then reinstalled HDJC5 package, and so the option D Console mapper has gone again.
Neither is the folder DJ Mapper available under Hercules\Audio.
Also tried to start the DJMapper.exe from HDJC4 with the HDJC5 installed, but then I got an error .msg file not found, something.
Where has the console mapper gone to?
Did Hercules wimply forgot to implement it with the new drivers?
Or is there any other reason?
geposted Thu 13 Jan 05 @ 10:21 am
I noticed that too. Whilst I do also use Joy2key, I liked the DJC mapper.
what do you mean?
is the midi mapper gone? so that you can't make custom actions to the console buttons anymore??
Yep, you're right. The midi mapper aka Console mapper has been removed from the HDJC5 package.
dixit, Hercules Tech Support team, see above answer from Hercules.
