Forum: VirtualDJ Skins
Topic: Can we please add KEY info?
djtopsPRO InfinityMember since 2006
Allright with the ability to now scan for song keys my mixes are going to a new level...HELL YES ATTABOY VDJ....now what we need is the ability to add the key at the top (say beside the bpm) in the track display info as each track is loaded into the player...Is that something that is done through the program code - or - via each individual skin....Can we add this to the to-do list gang? Anyone else feel like the key data in the track display field is a valuable add-on? I use the denon 4500 controller...so I am glad to see skins in the works for that, but my favorite skin is currently the DN S3500 suggestion by dj angel mix.. could someone add the key data field to this skin?
geposted Thu 31 Jul 08 @ 3:17 pm
jimmy bPRO InfinityMember since 2007
Some Skin makers have included the Key info on there skins, you will have to just look and found one that does.
geposted Thu 31 Jul 08 @ 4:23 pm
ciocePRO InfinityMember since 2004
geposted Fri 01 Aug 08 @ 2:55 am
listen2PRO InfinityMember since 2005
geposted Fri 01 Aug 08 @ 8:13 pm
