I am looking for the setting to switch the audio output from my externam Hercukes RMX to the iMac's internal output , so I don't have to use the analog out on the console. Where do I find that setting? Thank you.
    geposted Thu 31 Jul 08 @ 4:23 pm
          Hi connectaapi, i don't think that is possible in VDJ Le. I think u can only use the Rmx as its soundcard but i may be wrong as i dun have that VDJ Le version. Maybe someone who have that can verify it.
Cheers;)
    Cheers;)
geposted Thu 31 Jul 08 @ 4:41 pm
If you are using 5.2 pro version, go to the sound set up, choose single output, then simple in the sound card. After that, select built-in for your driver.
geposted Thu 31 Jul 08 @ 10:33 pm
          You can also select headphones output, 2 cards, and then your choice of drivers.
    geposted Thu 31 Jul 08 @ 10:39 pm
