Hi
I've made several clipbanks by copying and renaming the dll file, but when I load a video it changes all the different clip banks with the same video so having several is pointless.
I'm preitty sure it didn't used to do this. Don't know what I have changed since the last time I used it???
Any ideas?
Thanks
Any ideas?
Thanks
geposted Sun 03 Aug 08 @ 11:02 am
revert back to the original clip bank you could do that then, i'm sure norway said it was not possible in the latest edition v1.2, delete latest edition and re install old edition from plug ins > video,
geposted Sun 03 Aug 08 @ 12:06 pm
No version 1.2 can be used multiple times by copying it.
How did you name the .dll files ? And did you only copy the original dll and rename it OR did you copy and rename all 3 files? You should have only copied and renamed the .dll file.
geposted Sun 03 Aug 08 @ 12:38 pm
I copied and re-named all the files.
But have tried just copying the .dll and renaming that one and still get the same problem.
So It does work with clip bank 1.2 then ? If so I will try re-installing it and starting again.
geposted Sun 10 Aug 08 @ 4:22 am
