I am looking into doing karaoke. I use VDJ all the time to DJ, but I keep hearing about a plugin for karaoke and there being a waitlist for singers. Where do you get this, I can't find it. When I open VDJ and go to effects I see the word Karaoke on there, but when I highlight it there is nothing there to actvate and what not. Please help...
geposted Mon 04 Aug 08 @ 4:08 pm
you must have your karaoke files selected for vdj to see them, ie the drive that they are in and folder, also you need to activate it (centre box) and then make use of the other three windows to the right and above of this box
geposted Mon 04 Aug 08 @ 6:04 pm
When I click on Karaoke, there is nothing that says to activate it, and the other 3 boxes are not there.
geposted Mon 04 Aug 08 @ 7:07 pm
Hmmmmmm...Odd. Is video enabled? Is "show karaoke" ticked in the browser? What version are you using?
geposted Mon 04 Aug 08 @ 9:46 pm
I am using Version 5.2, and I did tick the show Karaoke. I have to check if video was enabled, but pretty sure.
geposted Mon 04 Aug 08 @ 10:48 pm
I am using Windows XP with nVidia 8600m GT video card. I get video freeze when I use hardware excelleration, but video still play no problem. I dont understand why this would havppen. Works fine on my desktop with Vista.
geposted Mon 04 Aug 08 @ 11:05 pm
jimspinnin,
As with all plugin problems, make sure you have the latest DirectX runtimes:
http://www.microsoft.com/downloads/details.aspx?familyid=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
A quick look into the DLL shows it needs the February 2007 update to DirectX 9. The link above will update your DirectX install to the latest version (June 2008).
geposted Tue 05 Aug 08 @ 5:46 am
What is the advantage of using the karaoke video effect? I rip my CDG + MP3 karaoke files to my hardrive and play them like any other track. They show up on the video output just as you would expect.
geposted Wed 06 Aug 08 @ 7:45 pm
Check out page 54 in the manual for a detailed description. In short, it sort of works as a rotation manager with some added features onscreen. I like it on the whole :)
geposted Wed 06 Aug 08 @ 7:56 pm
I looked through every manual for a detailed description of the karaoke video effect and could not find anything beyond the mention that the software will play karaoke files. For instance see VDJ User Guide Version 5.0 Revision 4 page 50. Any suggestions on finding more detailed instructions would be helpful. Thanks,
geposted Thu 07 Aug 08 @ 11:58 am
I can't get it to work, so I am just going to buy a karaoke program like Roxbox or Compuhost. They actually let you customize the display, have a filler music option, and full singer management. Thanks for the help on this issue guys.
geposted Thu 07 Aug 08 @ 2:30 pm
@sas2005
You can find the 5.1 manual by clicking here.
@jimspinnin
Sorry you couldn't get this sorted out :(
@jimspinnin
geposted Thu 07 Aug 08 @ 4:34 pm
Thank you very much discjockeydoc. When I clicked on my Karaoke video effect and activated it, it was pretty easy to operate. But now I know Wiki exisits which is great!
geposted Sun 10 Aug 08 @ 9:09 pm
Yes, it's a great new feature of the VDJ communty!
geposted Mon 11 Aug 08 @ 5:47 pm
hehe, if you had read this at the top of the page it may have saved you sometime, glad your sorted now anyway
geposted Mon 11 Aug 08 @ 5:51 pm
HOW I CAN TAKE OFF THE AUDIO FROM THE VCD WHEN I PLAYING ON VIRTUAL DJ KARAOKE
geposted Wed 20 Aug 08 @ 7:45 pm
Hi, firstly turn off the caps;)
Do u mean mute the vocal n just the music playing from karaoke VCD?
Use the Balance stereo/mono plugins.
It could be found here.
Regards.
Regards.
geposted Thu 21 Aug 08 @ 8:23 am
I am having the same problem as Jim.
When I click on the karaoke plugin the activate button is blank and no other controls. I am in a karaoke folder, karaoke is selected in the browser and video is active. Have tried reinstalling vdj v5.2 but no change.
Am using a Toshiba A300D Laptop
Dual Core 2.1GHz
3GB Ram
ATi HD340 256 dedicated graphics
Directx 10
Vista Home premium
Would like to get this sorted before the end of the wek if anyone has any ideas??
Cheers
John
Dual Core 2.1GHz
3GB Ram
Directx 10
Vista Home premium
Cheers
John
geposted Sun 24 Aug 08 @ 7:36 am
I assume you've installed the latest DirectX runtime libraries?
geposted Sun 24 Aug 08 @ 7:59 am
OK, managed to sort it.
I installed directx9 aswell as 10 and that seems to have resolved the issue.
Cheers
John
Cheers
John
geposted Sun 24 Aug 08 @ 8:03 am
