hello,
I need help.
my set us is this:
Decks: pioneer CDJ 800 x2
Mixer: Numark em 460 4 channels
Soundcard: Maya USB 44
computer: Laptop running Windows vista 32 bit
heres my problem, everything works fine i can control every thing from the decks except cue and loop. when i press cue it just pauses and when i try to loop from the decks nothing happens... Is there a plug in i need or something from the config menu i missed???
I need help.
my set us is this:
geposted Mon 04 Aug 08 @ 9:27 pm
what mode are you running: ABOSLUTE, RELATIVE, OR SMART. I would try switching these setting. you can find them under TIMECODE CONFIG.
hope this helps, holla back
geposted Mon 04 Aug 08 @ 9:42 pm
Thankx for the response ....I tried all of them and non of those work... am i supposed to see the the fader move on the software when i move it on my mixer??? cuz thats not happening either
geposted Wed 06 Aug 08 @ 8:35 pm
No, also, what version of VDJ are you using?
geposted Wed 06 Aug 08 @ 8:37 pm
Im using version 5.0
geposted Wed 06 Aug 08 @ 9:28 pm
can someone help me on this issue please im really stuck
geposted Mon 11 Aug 08 @ 9:51 pm
