Forum: Old versions
Topic: Pioneer CDJ-400 midi map question
If I plug in two CDJ-400 players into my computer, each with its own separate USB input, and have my sound card setup as an external mixer (DJM-800 also Midi input into the computer) and a 2 card configuration (one for the left deck and one for the right deck)
Will Virtual DJ be able to recognize each deck separately if they are both using the same map? Or do I need a separate map for each player?
For Example: I don't want to be using the mapped jog wheel while cuing up a song on Deck one with the LEFT CDJ-400 and have it affect the same midi mapped jog wheel simultaneously on Deck two while its playing the current song and vise versa with the RIGHT CDJ-400
The mappable functions are the SAME on both players, how does Virtual DJ recognize each player as separate units and that I only want my left CDJ to control the left deck and my right CDJ to control the right deck
I hope this makes sense.
geposted Thu 07 Aug 08 @ 8:12 am
