Forum: VirtualDJ Skins
Topic: Reset Buttons
I'm new to skin design & I am trying to add a button to a skin that will reset Gain & EQ at same time, & another button to reset Key...
Can anyone tell me what the "action=" should be for these functions ?
Thanx P
geposted Thu 07 Aug 08 @ 9:56 am
Gain and EQ reset at the same time isn't possible unfortunately.
Key reset action should be:
<button action="key" value="reset">
As you are a user of VirtualDJ since over a year, you should consider buying the software.
At least not with skin engine. It is possible to create a keyboard shortcut/midi macro for this
by applying two functions to the same key/midi command.
