I noticed the Key Changer plugin doesn't work anymore since version 4.0
Started doing karaoke work again and the regulars are asking for songs o be key changed.
ALSO: Could this be built into VDJ rather than a plugin that I could just assign keyboard shortcuts too or on my MIDI controller.
Thanks,
Ross.
Thanks,
Ross.
geposted Sun 10 Aug 08 @ 8:51 pm
If I'm not mistaken, the key-changer is now an integrated part of VDJ, under the audio effects tab. I suppose it's possible that, if you already had one installed, the newer version might not have installed its own, but I'm not sure.
geposted Mon 11 Aug 08 @ 5:51 pm
Yes you are correct, a re-install quickly sorted that out although I should have spotted that on my Mac before now.
I normally use external effects anyway.
Thanks again.
Just delete this post if you like.
Ross.
Thanks again.
Ross.
geposted Mon 11 Aug 08 @ 7:54 pm
No problem, glad to help, and happy you're up and running ;)
geposted Mon 11 Aug 08 @ 8:41 pm
