I just reinstalled my virtual Dj to the lastest version and when I take a look at the music in the Itunes music folder (where all my music is stored) it only showed the songs of the cd's I loaded today. To the right of the search bar when I select the music playlist it does show that i have over 11000+ songs. But when I go to the actual folder it's only showing what I loaded today.
I'm trying to get everything situated so that I can then start the BPM analyzing process since i know it's going to take forever. By the way, is there a way for virtual dj to detect the songs that haven't been analyzed and just do those, Instead of analyzing the whole library again?
geposted Wed 13 Aug 08 @ 8:47 pm
I'm not sure about the iTunes issue (I don't use it). Have you tried a "fix" and "clean" in the config>browser tab?
As far as your second question goes, you can create a filter folder. The syntax is ISSCANNED=0. When you click on the folder, it will contain a list of all of the files that have not yet been scanned for BPM.
geposted Wed 13 Aug 08 @ 9:49 pm
