I have a few tracks that are getting cut down, like from 5 mins to 1:15. I check on other players and they work just fine from start to finish, but when I drag them to DJ, they get cut up and doesn't scan the entire song. Any thoughts?
geposted Sat 16 Aug 08 @ 9:34 am
I've never had a problem like yours.
Try to change loading max in options pannel by changing this worth in Always
geposted Sat 16 Aug 08 @ 10:32 am
I have similar problems loading some .VOB's where a 4-5 minute song will be 5-10 seconds give or take. Forcing a full analysis manually on the song (instead of having it do the first analysis when you drag it to a deck) works though. Even if it's already gotten the wrong length, just go ahead and right click to analyze the BPM and it will fix it.
If not, then you may want to re-encode your audio.
geposted Sun 17 Aug 08 @ 10:15 am
