I have the Mackie powered 15" subwoofer which I use with the powered EV 12" speakers. The 1 Mackie sub is unable to keep up with the EV tops. I also have a KV EX 2.2, which I use for school dances, but it is more difficult to move around.
I would like a sub which is the size and weight of the Mackie 1501 but puts out more punch to keep up with the EVs. I do have an extra amp, so maybe I should consider an unpowered sub.
Can anyone suggest a subwoofer?
geposted Sun 17 Aug 08 @ 4:03 pm
well you can't go wrong with unpowered sub the only thing more things to take along
geposted Sun 17 Aug 08 @ 4:23 pm
Have you ever thought about just adding another Mackie and running the two side by side in a mono config?
I really like the sound of the 15" Mackie sub... not a fan of the 18" version.
You can also take a look at the JBL PRX518S. It is lighter than your Mackie and it performs quite well for me for a lightweight 18" sub.
HOP
HOP
geposted Sun 17 Aug 08 @ 5:16 pm
I use one of these. Been using it for four years. 1000 watts of power, built in power amp, able to drive off board speakers, built in crossover. Its a good unit, I have personally seen mine bring dust down off of rafters with it. Here is the best part, it has built in coasters for easy moving.....
geposted Sun 17 Aug 08 @ 5:21 pm
i wouldn't mind hearing that peavey one o dese ole daze.......
i like cerwin vegas
i like cerwin vegas
geposted Sun 17 Aug 08 @ 5:27 pm
I am trying to make things as easy as possible, so I decided on using only 1 sub for setup. I am interested in the JBL PRX518s. That is a possibility.
geposted Sun 17 Aug 08 @ 6:04 pm
We use the JBL MRX-528S, http://www.123dj.com/speakers/jbl/mrx528s.html
These subs kick so hard we have to put anti-skid mats between the subs and the top enclosure (which weighs 94 lbs) or it will vibrate the mid/high cabinets right of the top of the sub cabinet which is a very bad thing for someone standing near.
We use a QSC RMX 5050 to power the subs, they will not only knock the dust off the rafters they will UNSCREW nearby light bulbs and knock paintings off the wall.
:0)
:0)
geposted Sun 17 Aug 08 @ 6:24 pm
Considering the Yorkville NX720S Powered sub. This would be a step up from the mackie 1501 and it is lighter at 73 lbs.
geposted Sun 17 Aug 08 @ 7:34 pm
QSC PLX3206 amp running 4 dual 18 TXD218 Turbosounds. Use a crossover some kind to really tweak it to bring the heat!
geposted Sun 17 Aug 08 @ 8:23 pm
ive always been a big fan of electrovoice speakers myself
geposted Sun 17 Aug 08 @ 10:50 pm
Try Cerwin Vega...it will shake your ass within 5 miles radius.
geposted Mon 18 Aug 08 @ 2:13 am
Weight always becomes the killer of powered subs..
The only subs I can think of that won't break your back yet have decent output is the EV sbA760 (760watts RMS) and the Mackie SWA1501 (500 watts cont.)...
since you already own one mackie your best bet is to get another one and place them next to each other (giving you a very nice 3 dB boost in volume)
geposted Mon 18 Aug 08 @ 11:21 am
cerwin vega 18 or 21" powered subs. The 18" has a little more punch, the 21" is more on the shake the ground and rattle your teeth side
geposted Mon 18 Aug 08 @ 1:04 pm
If you want great sub and not hung up on name here is a well built and great sounding sub... http://www.b-52pro.com/models/ACT18X_ACT18.html
Not only is it powered but if you feel the need to add another sub to your setup later on you can buy its unpowered brother and the amp will drive them both.
geposted Mon 18 Aug 08 @ 1:36 pm
Check Out these subs from carvin. The price is alot cheaper than JBL Mpros and push more watts. 800watts RMS Nice... The Price is excellent and they use Custom " Eminence Drivers "
https://www.carvinguitars.com/products/single.php?product=LSX1801
https://www.carvinguitars.com/products/single.php?product=LSX1802
Ive used JBLs & now i use carvin speakers..
geposted Mon 18 Aug 08 @ 7:45 pm
which one you used?
geposted Mon 18 Aug 08 @ 8:52 pm
Whats Up Phil.. I use the JBL Mpro 118s and it pushes 600 watts rms. Its a single subwoofer and it sounds Ok. I would rather have the carvin because it handles 800watts rms. I bought the JBls before carvin came out with this new more compact model. I have carvin speaker tops and they sound better than My JBL eon 1500s. The bass is more tigher and the highs are louder.
geposted Tue 19 Aug 08 @ 10:24 pm
ok got a friend that's all he used is carvin i may try the power sub
geposted Wed 20 Aug 08 @ 6:20 pm
I don't know the model number, but Yorkville has a kick a$$ powered sub that booms. My buddy has them, and they rock. Makes my JBL sound like an MTX.
geposted Wed 20 Aug 08 @ 7:39 pm
I have been using the cerwin vega earthquake for years and love it. The kids enjoy it at the dances and for outdoor parties the cops always show up.
geposted Sat 23 Aug 08 @ 11:16 pm
